sportsmanphil
Thread starter- Joined
- Mar 8, 2009
- 257
Once in a while this happens, did it again today.
Ive been running the boat several times a week and an issue came back up again today.
Motor runs 100% and then all of a sudden it doesnt want to idle low or in neutral. It stumbles and will die. Will not crank back. If I lift the fast idle it will crank and I have to drop the fast idle and push it into forward quickly. I have good spark. The prime bulb is tight.
When it done this in the past it was fine a few days later on its own.
Today, when I got it out of the water I took the lid off the engine and found a lot of fuel all over the carbs and even running down the LU.
Any ideas at what would cause a random low idle or low speed issue with the carbs and fuel coming out of the carbs?
