Hi,
I have some starter problems with my -06 50hp Mercury. The problem is that starter motor keeps spinning after the engine starts, but when I put the gear on F or R the starter stops spinning. I think it is not normal that when engine is in N after I have started it and the starter keeps still spinning?
This is also a issue because when i change from F to N it will hit the flyweel and after that the starter starts to spin again. What could cause this kind of problem, any help very very appreciated?
Also the spinning stops when I move abit the remote control lever in N position(so before the gear goes in)?
Seems to be someway in connection with gears and electrical wires? but I cant understand it how
Thanks!!
Jake
Thanks!!
Jake
