mercury 50 not running right
wbrooke
engine starts ok and idles ok when full power will not go very fast an ideas just plods over the water new to boats anyone help
fishingdan
Re: mercury 50 not running right
The folks here are very helpful, but they will need more info before they can help. <br /><br />- What year is the engine?<br />- What size/type of boat?<br />- Since you have owned it, when did it last run well?<br /><br />Engines need fuel, air and spark to run. <br />- Do you know if you are getting spark to each of the cylinders? <br />- What is the condition of the carbs?<br /><br />If you plan on working on it yourself, do yourself a favor and order a service manual for your engine. It will be very helpful.
wbrooke
Hi there guys, I've never run the boat in water since I bought it. I've put new petrol tank, new fuel line, new filters and a new gasket on the top carb. The engine runs and revs well on the idle lever but as soon as I engage gear and try setting off, my motor dies. Then it only starts using easy start. It's a early eighties (80's) mecury 50.4 cylinder. I've checked rev and gear cables and they are fine. I have noticed some bubbles in the filter. Any help much appreciated.
btatum
how old is the motor and when was the last time anyone had it on the water?<br />i feel the carbs could be your problem. the engine doesn't need much fuel to rev up in neutral but when in gear it a whole different ball game. if it's been a while since the motor was running properly i'd look at the carbs. you may be able to take them off and give them a good cleaning and be ok.<br />ck your plugs also. it may be time for new ones.
