Re: Mercury 50
the shifter cable connect to the side of the engine. be caferul to undo the screws a little at a time not to totally remove the screws just enough to remove the cable or you will be searching for them in the bottom of the cowel (NO FUN) I was hoping i had a picture of something sowing the cables. No luck. They are on the left rear of the boat going into the engine through a little port hole in the cowel you have the throttle and the shifter cable there.
