mercury 500
Im just curious about how good and reliable a 1971 mercury 500 and about how powerful the water comes out of the water port
Laddies
Banned
Re: mercury 500
The 4 cyl. 50s were one of the most reliable ever built. The telltale should have a steady stream of water but they do plug up from silt and have to be cleaned once in a while
tmcalavy
Re: mercury 500
Had a 73 Merc 500 and never got a real powerful stream out of the telltale when the engine was idling between 800 and 1000 rpm. So that was kinda deceptive, as it would put out a good stream at higher rpms...on the muffs and out on the lake. If you can touch the waterjackets and hold your hand on there when it's running, the water pump/cooling system is doing its job and everything is ok. If it's too hot to touch, time for some pump/system maintenance. Those are great outboards, very strong and reliable.
Chinewalker
Re: mercury 500
I agree - great motors. However, there were some weaknesses. Keep an eye on all wiring under the cowling. Older Merc wiring had a problem with the sheathing cracking and crumbling. Also, the early 1970s models still had steel shafts that were prone to rusting, particularly under the waterpump cup where the upper main seal is. If you're getting water in your lower unit oil, there's a good chance that's where it is coming from.
Unless the guy you're buying the motor from can produce an invoice showing that the waterpump was changed within the last year, replace it. Cheap insurance...
- Scott
