Mercury 60 HP
pickard1
Hi everyone,
I am rebuilding the carbs on my 1988 Merc 60HP ELO, serial # 0A740965.
Can someone walk me through the float re-install?
(best method plus exact measurements I'm looking for).
Also, I think my fuel pump is fine but is there a performance test to know for sure?
pickard1
I found the info. and set up my carbs. The engine is running great now. 11/16" from the carb body to the top (bottom) of the float.
There is a fuel pump test, but since the engine is running good, no need to check it at the moment.
Texasmark
Easy way to test the fuel pump: If the engine only runs with you squeezing the bulb to supply fuel your pump is sucking air!
