mercury 650 (65 hp) help
marino5656
hello im is new in this forum,need help for startin my boat.i can used.so not have firing spark plus....:confused:
Darren052
Re: mercury 650 (65 hp) help
I have one like that to. The others are going to tell you you have to give a lot more details then that. :confused:
jbjennings
my merc 650 has a key to operate the starter and a black button to choke it. I first check to be sure my primer bulb is firm on my tank, then set my fast idle lever, then turn the key while pushing in the black choke button. When it cranks, I let go of the choke button and let it run for about a minute on fast idle. I then push the fast idle lever down and go about my business.
Later,
JBJ
jbjennings
I just reread that post and can see that you have other problems but I can't understand what you're saying. Definitely need some more details.
JBJ
