sutor623
- Joined
- May 23, 2011
- 4,089
Since you guys have all helped me so much on my lower unit venture (Faztbullet, Emckelvey, ThumbPkr, etc.) that I decided to post my venture, and the differences that I noticed between the 150hp and 65hp housings.
First off, there is a difference in the driveshafts. The early 650 4 cyl. models had the o-ring on the shaft, and the newer motors (as well as the Inline 6's) had the o-ring in the crank. Well this poses for a problem, because if you use the incorrect driveshaft on the 650 then you cannot keep the proper marine grease between the powerhead and the driveshaft, causing them to get stuck, and a big headache during L/U overhaul. (We have pinpointed that the replacement lower unit that I have is off of a 150hp.)
I chose to grind out the slot for the o-ring, instead of search for the elusive tools required to break the lower unit down and try and swap driveshafts. Here is a pic of the finished grind.
Next thing that I thought I would point out are the part numbers of the waterpump kit that I used in my Lower unit.
In the older 650's there was a flush plug in the side of the lower unit housing, that went straight into the waterpump base. Since I was using the housing of the 150, my water pump base was sealed off and does not use a flush plug. So I decided to pop the base out and change the oilseals, o-ring and gasket underneath it. When I got the base out, I noticed that the plastic was slightly warped. NO WAY was I going to risk toasting a motor with 125# across the board, by neglecting to change the base. Luckily I had a good aluminum base off the 650 lowerunit that had seized up. But, the base off of the 650 had one main difference. (Actually it had 2, but I didn't realize it quite yet.) The waterpump base had a flush plug hole in it. Sooooooo, what did I do, I went to Lowe's and got a set screw, put permatex locktite on the threads, and screwed it into the hole to permanently seal off the flush hole.
I came home from work the next day and was SIKED that I was going to be getting my lower unit ready for install. An when I got home I realized that there was another difference between waterpump bases.:facepalm:
I will continue on a reply.
