sutor623
- Joined
- May 23, 2011
- 4,089
Okay guys, I have been working on a merc 650 for a while, and I got it running great with some sea foam and a lower unit overhaul. I had never had the motor in actual water, but on muffs it always started up easily, and idled great once I got it warmed up.
We took it out for the first time today, and the motor would not start. The only difference was that the motor was submerged in the water, rather than placed on muffs this time, and we drove about an hour when the temperature was around 40 degrees. We decided to head out with our electric motors, and they did fine. I tried to crank the motor over numerous times throughout the day and one time it sounded like it wanted to go, so I tried a few more times and it cranked over. I let it idle for about 10 minutes. Then we head off and eventually I hit about 3/4 throttle. The motor sounded and ran great. It pushed my 16' starcraft so well that I did not feel safe pushing the throttle any further. It was flowing water without an issue at all. After about 15-20 minutes, we slowed down to do some trolling, and I put the motor into neutral and let it idle to set up our gear, and it died. I could NOT get it started again, for the rest of the day.
I was wondering if you guys have any ideas. I was thinking that the added back pressure of the exhaust being in the water reduced the "scavenging" effect of gas and air, and basically shows that I need fuel pump/carb work. Has anyone on here had the issue with the motor not starting in a.) the cold weather or b.) only when the motor is submerged??
