mercury 65hp 1969 question
dblok4eva
ok first off im 90% sure its a 1969 s/n is 2713867 and its a 65hp merc650 please correct if im wrong
here are my questions i need a wire harness with 6 pins (photo below) all i have seen are 7 and up pin size also if anyone knows what part number i would need for wire harness i also need the remote throttle side mount and if possible part number for that or if they are somewhat universal
also i need the throttle cables im pretty sure there is only one
can someone please give me information about this motor does it have reverse?
2-stroke correct ?
any known problems with this peticular motor?
thanks in advance guys
OldMercsRule
Re: mercury 65hp 1969 question
#1. The 650 has reverse, (as yers had at one time as well).
#2. The internal harness can be purchased right here on iboats.
#3 The external harness and cables also can be purchased right here on iboats.
#4 I have a factory fresh (still in the plastic) "Merc corntrol" that needs the external harness and cables, (see #3 above) PM me if you are interested.
Me over priced $.02. JR
Laddies
Banned
It's not uncommon to have extra holes in the plug in there are 2 harnesses one is for battery powered CD and the other is for magneto and ADI ignition systems, I think that your engine is battery CD remove the cowl and see if there are 3 wires come out of the dist. that makes it CD, if there is only 1 then it's magneto. If it is battery powered ign. then any box and harness from 1967 to 1976 thats for battery ign. will work, check eBay and dealers bone piles there are a lot of used ones out there.
