Mercury 7.5 choke
Vahevala
Almost done with a major redo of this motor, just put a rebuilt carb on the engine :) and noticed that the choke shutter was not closing all the way. :confused: Is this ok or should it be closed all the way. :confused: If its to be closed thightly is there any way to adjust the choke cable. Any info would be thankfull. :D <br /><br />Shawn :cool:
Big Al1
Re: Mercury 7.5 choke
My Mercury 6hp is very hard to start without the choke tight on the carb. I even had to add a washer to push it tighter against the carb. I’m not familiar with your motor though since mine doesn’t have a cable. You should be able to adjust it. A hard to start motor is a real pain in the a**, especially on a fast moving river with many overhanging trees.
