Hello all<br /><br />I'm getting ready to do some electrical work on my motor. It was sunk last fall, so the connections that were live to the battery are corroded. I've rebuilt the starter motor. I'm planning on replacing the solenoid and the rectifier. The solenoid is no problem, but the rectifier is a little confusing. I went to the Mercury site to look-up the part number and things get a little gray. I can't just look at the part as the motor is up north. If my memory is correct the rectifier (as shown in the diagram) is not available, and of course the alternate configuration is several hundred dollars. The motor serial number is 0a739861. Could someone look at that diagram on Mercury site and see if it makes sense to them. Any insight would help.<br /><br />Also I had to cut one and mangle the other starter mounting bolts, but can't find a listing for replacements. Oh and what size head is it, Doesn't appear to be standard imperial or metric.<br /><br />Best<br /><br />David
