andrewbabich
Thread starter- Joined
- Aug 31, 2009
- 85
My friend just inherited a 1978 tri hull with an 85 hp black merc on it. I assume the motor is 1978 as well, but not sure, and I'm in charge of getting it back to running condition. It was ran as a recreational lobster boat the last few years and its in baaad shape.
I have a couple 13 3/4 x 15 Johnson omc props from that era. Are they interchangable.
The prop needs replacing and
The rudder/ stabilzer tab thingy that hangs off the outboard near the top of the prop is all corroded and needs replacing. (whats this thing called).
The steering cable is shot and needs replacing too, unless I can un seize it. Any tips?
The below waterline area of the hull is red painted and all cracked and nasty. What should I do, can I sand it down, does in need replacing? I don't know why a fiberglass boat has cracking paint.
