thelostkiwi
Thread starter- Joined
- Sep 5, 2021
- 13
Hi All!
I have a Mercury 85 HP Thunderbolt 1977(I think)serial 7101664
It runs fine on muffs connected to a hose but when I took her out in the sea it starts well but runs rough and will go into gear and can increase speed slightly but once I open her up abit more she bogs down and will stop if I dont pull the throttle back fast enough.
Once I got her home and back on the muffs she ran perfectly and would get up to full throttle in gear with no problems at all.
The only thing I noticed is that the tell tale is a little weak on muffs and in the water, and that water is coming out round the prop right from when I start it before its had a chance to warm up.
This is my first Mercury so Im not sure how strong the telltale should be.
The previous owner had some work done a year ago so its got new plugs and new ignition panel thing. He had it running well on a freshwater lake last year with no problems and said its never seen sea water.
So as I use it in seawater could this be the problem or something else?
Any Help would be much appreciated
Thanks,
David
Thanks,
David
