Mercury 9.8 has spark, won't start
jeff_32
I have a 1978 Mercury 9.8 that will not start. Has good spark, tried squirting gas/oil mixture in carb...nothing. Tried starting fluid in carb, nothing.
Is this a timing issue? How do I go about changing the timing.
jeff_32
How did it run for you last season?----What happened?
It always started up easily. Until one day it didn't and noticed bad wires coming out of the switch box. I attempted to fix them but not enough good wire. Replaced the switch box. Now I get great spark but will not start period.
jeff_32
Although I have spark, could the trigger be the problem by throwing off the timing?
Put a few drops of fuel into each cylinder.----Put plugs back in.----Pull it over.-----Should bark / roar like a mad dog or lion.----If not try reversing plug leads.-----I say it is a timing issue.-----But you state that flywheel key has been verified good.
jeff_32
I tried to put gas/oil mixture through the carb again, nothing. I tried ether again...I know shouldn't do this...still nothing not even a cough. Pulled the plugs and put gas/oil in each cylinder and it fired right up. Then I was able to start it the rest of the day with barely a crank of the starter. Could a reed valve been stuck?
Thanks to everyone for all the help.
There is more than one reed valve for each crankcase.----There are 4 reed valves for the top cyinder and 4 reed valves for the bottom cylinder.
saltchuckmatt
Whatever is was who cares....count your blessings!
