mercury 9.8 hp .... water flows through but will not pee?
FLstraycar
can run hose, water goes through, but when i put in barrel and run, will not pee? new impeller kit and parts installed. no difference... what should i be looking at.... Thanks in advance. Susie
tphoyt
Is the water level high enough? Pumps are not self priming and need to be completed submerged. 6” to 8” above the pump.
Serial # is ??----Is the water level 8" above the impeller?-----What did the old impeller look like?-----Did the motor suffer from severe overheat ?
Did you replace the grommet at the power head to copper tube joint?
Are you in a deep enough garbage can?
flashback
Bugs like to nest in pee holes ,try to rod it out with heavy weed wacker string..
