Re: mercury 90hp 1984 leaking trim cylinders
Stuart, I have replaced the oring seals aroung the rods, on my '77 Merc inline six several times. I have have replaced the piston seal only twice in 30 years. The rod orings are of a common type, and are available anywhere. They are also easy to replace, if you have a spanner to remove the rod-end of the cylinder. The trick is not to remove the piston from the cylinder, since a special tool is needed to put it back. The piston detaches from the rod via a 9/16 bolt. Then you pull the rod out of the end cap and replace the oring.
