Rpiazza6857
Thread starter- Joined
- Oct 30, 2020
- 26
Hello all I have a new to me 90HP Merc that I cannot seem to get running correctly. So far I have rebuilt the carbs with kits and new needles, replaced all fuel lines, replaced enrichener solenoid, gone through the lync and sync procedure, replaced the plugs and wires, removed oil injection, new water pump and gear oil, and various other minor things. Compression is 120 dead even across the board with the engine luke warm and the throttle completely open. There is very good spark to all three cylinders. The issue is the motor will run until the top cylinder loads up at idle, it can be made to run longer by applying more throttle manually at the throttle plates but smokes badly and seems to have a miss. I used new spark plugs when testing and when pulling them the top plug is badly carboned and wet with fuel oil mix even after a short period of time, the middle and lower still look new. I am going with a starting point from the book of 1.5 turns from lightly seated to start with the carb tuning. I have verified the wiring from the switch box to the coils is correct. Wiring looks factory original and motor is very clean for it's age. I have tried adjusting the low speed needles and the low speed timing just to see if it would make a difference and it changes things slightly but engine does not respond to adjustments like I think it should. I'm not sure where to go from here, I plan on rebuilding the fuel pump to rule that out because it's cheap, and possibly swapping coils around to see if the problem follows the coil, could a coil be bad and still fire strongly? Any suggestions would be appreciated, thank you!
