markodecember
Thread starter- Joined
- May 9, 2008
- 12
Hi folks,
I went to see a boat the other day that had the above engine fitted to the boat.
Compressions were satificatory (135psi) but the problem is that it would only start and run on 1/2 to 3/4 throttle.:redface:
I rekon it has got to be a problem with the carbs being blocked and just needing a good clean.
What are all you thoughts on the matter?! Am I right to presume carb problem?!
It did look as it had been sat around for ages- only a dribble coming from tell tale and clearly not been moved for at least a year or two.
All replies very much apperciated.
Many thanks,
Mark.
Many thanks,
Mark.
