DamianJP
Thread starter- Joined
- Mar 25, 2008
- 612
First off here are the pics that go along with this.
http://s281.photobucket.com/albums/kk233/damianjp_photos/Mercury 1989 XR4 150HP/
I bought this rig with Top WH41 and MID / BOT WH27 it seems. At the start idle was ruff and top end okay. So I changed the idle jets because the 27's were off. And bam smooth as silk idle. I started to investigate my Main jets but broke 1 and quit after it was 20+$. I snagged a set of WH41's from ebay and so far the idle jets are all .052 .Then I had to dig in again and busted 2 more.
Lemme try and form this up
1)Whats the best method/tool to remove main jet plugs
2)Are bowls from my new/old set interchangable
3)Are floats (1 composite / 1 plastic) from old/new set interchangable
4)What should my jet's be on the 41's /it is Stock/
5)Do I really need to change the needle seat? If so whats the best method/tool to use?
Thanks,
Damian
Thanks,
Damian
