Mercury Classic 50 (45hp)
raray1221
Today on the water i was running my boat nearly wide open and suddenly the engine power cut in half. I immediately cut it off and tried to restart it and after a few tries it started back up. then once in motion running at 75% or so, the same problem started again, and of coarse the engine would not idle. I do not know a whole lot about fixing engines but i took both carburaters out and clean them and sprayed any visible holes and the bowl with cleaner. dried and reassembled and boat seemed fine. then once running again, same problem, any advice?
raray1221
Re: Mercury Classic 50 (45hp)
also i have checked the fuel hoses and they were clear. compression is good and spark is fine (again i just checked what i know how to check even though it was probably useless). Please help!
Laddies
Banned
It sounds like you are loseing spark on 2 cyls when warm, you will need to check for spark on all 4 cyls while it's acting up with a spark gap
raray1221
If I can't catch it in the act, what should I do/ replace to keep this from happening?
Laddies
Banned
Don't throw parts at a problem either fine it yourself or take it to a shop, ign. parts are much to expencive for that.
