mercury compression does it effect fuel
Faztbullet
Re: mercury compression does it effect fuel
Yes, if cylinder as no or weak compression the fuel pump cannot operate correctly as it is drive by the crankcase pulses...
The boat runs fine at idol speeds but when I throttle up it dies after about 30 secounds , the compression is 90lbs on 1,2 and 4 and 30lbs on 3 so could this be the problem, the carbs are clean and all the lines.
Faztbullet
Sorry but if that compression is correct that motor is in need of a rebuild as it will never run at that low of compression(30psi) and the pump is driven of #3 if i remember correctly.
dbrew
unfortunantly you are going to have to rebuild with that big of a variance in compression and 3 being so low you are going to need to rebuild or get a new power head, i would rebuild now because if you run it like it is you run risk of something bending ir breaking causing more $.
saumon
#2 in fact, but still need a rebuild!
