Mercury controls- question on ignition replacement
chrizzo
I'm in the process of installing an older Mercury Black Max outboard on a Tracker Nitro Bass Boat. I have the controls but no key, so I was wondering if anyone can help me out with finding the correct ignition to buy. It's a push-to-choke type ignition. I've attached a couple of pics of what I have. Is something like this http://www.iboats.com/3_Position_Pu...27382899--**********.431805479--view_id.39663 what I need? Thanks.
Dunaruna
Re: Mercury controls- question on ignition replacement
Yep, the one in your link would do the job. Off/ON/START, push to choke.
You could also get one that has accessories if you want, they are called '4 position' with push to choke.
chrizzo
Ok thanks I just wanted to make sure I was on the right track. I don't think I'll need the 4 position because the boat has a dash mount breaker panel that has a master on-off switch and all of the accessories (bilge, lights, livewells, etc.) are already wired through the panel independently of the ignition.
Thanks again.
ryvesy
have got the same control box that im trying to wire up to a 50hp mercury thunderbolt
have not conected any wire to the blue terminal on the swich box and still have no spark?the mercury switch is disconected
have checked with a meter and found that the blue wire is down to earth is this right?
CVX20SPRINT
If you get along good with your local dealer just take the controls to him and he will get a key for your ignition.I've done it a couple of times.First time I went in to buy a switch he asked me why I was changing it so I told him I didn't get the key with the controls.He told me to bring in the controls,he brought out a key ring with only about 20 different keys(he says that's all the different ones there are)and found me a key.My controls were older than the ones you have,but I'll bet it's the same deal with yours and no work involved.
P.S.Johnson controls were the same.About 20 different keys.
