renoduckman
Thread starter- Joined
- Mar 31, 2006
- 75
I have a 1988 80 hp 3 cylinder mercury. I have a miss on the lower cylinder that comes and goes. I changed the rectifier becasue i was not getting any charging. The system is now charging but the miss is still there. Also, it seem im getting 16 volts or more out of my system now. That voltage seems to high? It appears this motor has no voltage regulator. I can not find the specs any place that show what voltage this motor will put out? I have a manuel and good ohm meter. I suspect the stator but it seemed to ohm out ok. If anybody has any advice on the problems and the voltage output i will appreciate it. I am an electrician but not a outboard guru! Thanks joe
