Mercury engine data values
saaristo
I have equipped my Mercury 115 efi with SC1000 speedo and tacho. Including many other things it shows oil temp, oil pressure, water pressure, fuel pressure etc....all kind of temperatures and pressures, all very nice. Except that there is nothing to compare those figures with. None of the manuals and documents that came with the engine/gauge set describes any "normal" values of those temps/pressures. Any idea where to obtain those?
JimS123
If any of the parameters fall outside of the specifications, the SC1000 should provide an alarm waning to alert you of a problem. If you want to know what the parameter ranges are, call Mercury Marine's Customer Service and speak to a technician. He should be able to guide you to a link that shows the specs.
