The motor is a 1996 40 HP Mercury Tracker Force. The problem is that the tilt will only lower the motor and won't raise it. When I launced the boat last saturday it went up & down as designed. But after a couple of times raising and lowering it won't raise anymore. It does still activate to lower though. I did successfully jump the toggle switch to eliminate that. Thanks in advance for your help.
