ealoysiusc
Thread starter- Joined
- Jul 15, 2007
- 4
Hi! I've got a '97 SeaRayder with 120 hp mercury jet sport engine. It starts and runs fine until it gets close to being on plane...the engine struggles and I get no where. Here's what I've done so far...testing after each step with no resulting improvement.
Cleaned fuel filter screen and replaced in line filter
Thoroughly cleaned the two carbs
Replaced spark plugs
Compression check (150 lbs in each)
Spark...all four good spark
Replaced ride plate, gasket and screws
Impeller clearance 22 to 25,000
Inspected wear ring...no grooves or excessive wear noted
Inspected impeller...all blades look good...no dings or chips
I am lost. My mechanic friend suspected exhaust leakage into pump, but I can't see how that could be so since from intake grate to exit nozzle is a closed system. I guessed the high speed portion of the stator was bad, but he says it won't run if the stator is bad. I have the service manual but found no help there. Any help....advice would be greatly appreciated. My email address is ed_pam@bellsouth.net. That is "ed underscore pam"Thanks in advance. ED
