I got a 1974 Mercury 500 50hp and I took apart the lower unit cuz reverse didnt work. I am in the process of hopefully getting it back together. I just have to tighten down the bearing carrier and there are 2 sets of threads there. A smaller diameter hole with threads closer to the gears, and an outter set of threads with a slightly larger diamter. The threads on the inner diameter look pretty messed up, while the threads on the outer diamter look okay. I had to break the cover nut when I took it apart, so I got a new one ordered. Will the cover nut go on the inner or outter threads? If it wont thread on is it okay to weld the carrier on instead. Anyone else have troubles with these threads?
