Mercury mariner 25hp
Gabe kreuger
Does any one know how to reset the timing and shifter arms in this mercury? Model number 0C12xxxx also how do I post photos?
Gabe kreuger
The last time I had a new carb kit put in and the motor would crank and run fine on water ears but once I put the motor down into the water I couldn't get it to crank.
flyingscott
Unless you played with the timing rod it does not need to be touched. The only way timing goes out on an outboard motor is if something catastrophic happens and things get bent or you replace the stator. I would start with a compression test and a spark test.
Gabe kreuger
The rods have been adjusted. The last time I checked compression there was a split I will recheck compression and keep posting
flyingscott
What about the short rod to the magneto has that one been adjusted? If it was only the long rods you are fine and don't need to time it. Just a a link and sync
