Mercury not charging 650
smilesforu
Howdy<br />i got a 650 3 cylinder serial #3456151 mercury outboard that isn't charging.<br />I took a voltmeter and measured before starting and after it started. 12.4 in both instances. So from what I have gathered I should replace a rectifier. Heres my problem whats the rectifier? Is it the small square box on opposite side of switch box with yellow wires going to it?<br />Where can I get one of these rectifiers? and are they easy to replace? Looks straight forward to switching one out.
Hooty
Re: Mercury not charging 650
Welcome to iboats Marty,<br />Use the search function and look for "rectifier".<br />There has been a lot of discussion recently about the subject.<br /><br />c/6<br /><br />Hooty
smilesforu
Thanks for welcome hooty.. it should be here soon so I will try matching it visually :) <br /><br />Great site with lots of very very useful knowledge!! One of my members recommended it. Hope I can contribute something back.<br /><br />Tight Lines
smilesforu
Rectifier showed up today and was a very simple install. (little square box as suspected)The motor is now charging again... hurray!! Thanks for the help on this one and the magic search feature :)
