Mercury OB power trim problem
MarkMercury75
After winter storage my power trim will not raise or lower the motor.
The trim pump motor seems to be running fine. I opened the pressure release valve and can raise the motor manually only a few inches.
What could be holding it? Thee are no locks and with the release valve open you are supposed to be able to raise the motor.
I cannot get to the piston to check the fluid with the motor in the down position.
