wildsteelhead
Thread starter- Joined
- May 26, 2013
- 2
I am having trouble with my optimax. It fires up perfect at the dock then usually you can get out of the break water and cruise then it dies flat on its face. I have replaced the antisiphon valve the fuel lines the fuel filters, ignition switch, spark plugs, batteries, primer bulb, checked the relays trim and ignition. had the local shop check it out and they ran it for 5 hours and it never died, then I took it out the very next weekend and it died 8 times in a quarter mile. (every time it dies it fires right back up). Left it in the marina and went back to the shop on Monday and told them to go for a run with me. We had it hooked up to the ddt and fuel and air pressure gauges and when it did die it did not lose air or fuel pressure, also it did not throw a code, and the computer did not die. they called mercury and mercury was very adamant on this grommet on the high pressure pump in the vst, replaced it went halibut fishing and ran for about 5 miles then died, and died a few times after that. on the way back in it died about 9 times. the next day it died about 9 times going out then only 2 times coming back in. I am starting to think that it might be the crank position sensor getting warm or shorting out.
any help would be great.
