Mercury outboard Stator
352teetime
I have a 1991 Merc outboard, purchased in the last year, used from another owner. It has a miss at about 2K rpm up to 3K rpm, and then seems to smooth out (or not noticable)
I took it to a shop and they found it has a 3 cyl stator. The outboard is a 4 cyl 115 HP Merc. Everything I have read about a stator does not explain how any ignition timing is a function of the stator. Just wondering, if there are any good links which can explain this?
Texasmark
The electrical pickups under the flywheel consist of 3 sources: Battery charging AC power, Capacitor charging which stores the energy dissipated in the spark of the spark plugs, and triggers to cause the capacitors to discharge.
The First two are on the perimeter of the flywheel the latter on the inside. Magnets are part of the flywheel.
All circuits consist of a Permanent Magnet (flywheel) and a iron core coil (stator pickup), multiplied as many times as is necessary to get the necessary result. As the magnet on the flywheel passes the iron core, it induces a pulse of current in the windings (V=L di/dt). The amount of power generated depends on the magnetic flux [size of magnet (gauss), spacing (air gap between the "primary and secondary"....magnet to iron core gap) and speed in passing].
Timing on the AC sinusoidal power to run the battery charger circuit isn't critical.
The Capacitor charging pulse circuit has to get the capacitors fully charged prior to the trigger coil picking up the trigger, repeated as many times per RPM as there are cylinders, with the spacing staggered, corresponding to the cylinder arrangement.
The trigger circuit has to develop the trigger such that the trigger device (SCR or MOSFET) fires and dumps the capacitors through the high voltage transformer in time to correspond to the piston's position for that cylinder such that the designer's criteria can be met for idle RPMs determination and timing, and WOT spark advance for plug firing. On my engine the the magnets are fixed but the triggers are adjusted, via the spark advance arm on the throttle linkage, with respect to the position of the respective piston position such that at idle the plug fires around TDC while at WOT the plug fires 22* before the piston hits TDC.
Not a professional. Just the way it looks to me.
sam am I
You're quite welcome TM. Yeah, it does sorta say it all but, your explanation had it very well covered as well, just figured some people are visual too, killed both birds....
