Mercury Power trim unit,Do you bleed them?
wilson750
I took my unit off because of problems and cleaned it up,and now it gets power..When i fill it back up do you have to bleed them? Or just fill it and go?
Its a 88 Mercury 115.. Thanks
Barnacle_Bill
Re: Mercury Power trim unit,Do you bleed them?
Raise and lower it several times. They are self bleeding.
wilson750
Great,Thanks for the reply..Fill it with the unit up or down?
jimg984
with tilted up
jimg984
sry, saying it that way maybe confusing.. the hyd cyl should be fully extended out and fill the pump to the marked level. careful not to over fill it
wilson750
Thanks Jim, Should i stop when i see it at the threads? I was going to use power ster. fluid since it is red now..
Thanks for the help!!
jimg984
yes, fill to the bottom of the oil filler hole.. not sure what the red fluid is...
my book says to use MS, SD,SE,SF, 20W or 5W-30 or 10W-40 OIL. if you wait awhile more people is sure to help,,, don't think would be good mix
jeff_smith_0423
Pretty sure that unit needs ATF - check your service manual.
wilson750
Thanks for the help.. I dont have a service manual or i would check..Hopefully someone on here will help out!!!
Barnacle_Bill
Book says use 10W-30 or 10W-40 auto oil. SAE 30 may be used in the tropics.
wilson750
Thanks, Motor oil it will be.. I guess i have to get all the red fluid out..
G_Lipe
I've got a 50 horse of the same vintage that calls for Dextron III transmission fluid in the tilt and trim (i'm guessing that is what the current red stuff is)
wilson750
Yeah im sure it is what is in mine also.. I guess any of them will do???:eek:
