Faztbullet
- Joined
- Mar 2, 2008
- 15,937
The picture you posted is a Bigfoot or what they call Command Thrust unit using the 13-14" diam props, a standard unit uses a max 12' diameter. Need to drop it in diameter not pitch....
Must be something different in your country as the Merc website plainly states motors come with no props or controls unless a tiller model and that comes with no prop.btw was delivered factory propped with a Black Diamond 11 starter pitch, same as the rest 3 motors in stock.
Checked the motor's cowl, it's definitely a Bigfoot 2006 year model. Was reading that this type of motor with taller and larger lower leg is best suited for toons, water houses, barges applications not Ribs. There are no Black Diamond props with less diam in the 11 pitch model which are 10-7/8. Diam is what the prop manufacturer wants to build his props with, pitch is all what matters.
Saw at the Merc store a brand new 4 stroke 60 HP GT Command Thrust model, specs states being a 2:33:1 gear case ratio, asume that the Bigfoot 60 has a different ratio, right ?
As the motor has very low hours of use, assume that the tach is in good working order. Probably impossible to check it with another one, but will like to measure its Top speed with a GPS in a long run.
According to IBoats web page information Diameter is the width of the circle that the prop would make when rotating.
The diameter can vary by up to 1/2" with no Discernable Change in Performance. So what's your idea about it ?
Happy Boating
Finding a less diam prop with same 11 pitch will be more difficult than finding a needle in a haystack, that's for sure. So you guys don't think that by going for say 2 less in pitch with much less diameter will do the trick ? Need to bump max wot rpm to 6 K lightly loaded with 2 or 3 max up.
Happy Boating
If this is correct a prop change to a 9" will get a extra 5-600RPM but will slow the speed down about 2-3 MPH .The Bigfoot or CT unit do not like being run deep and prop needs to surface a tad. If I had it at my shop I would loose the Doelfin which increases drag if not running on surface, and raise motor1 hole on transom.The issue with this 470 Rib is that the hull is nearly 20 years old, develops a tremendous front hull drag due to its odd shape when on plane at speed. Would say it's worse than a dog when running. Splashes too much water at side of front hull which slows the combo real bad.
