Grasshopper187
Thread starter- Joined
- Feb 23, 2013
- 15
I have 1993 Sea Rayder F14 with a 90 hp Mercury Sport Jet engine. Everything runs well except for an oil leak at the bottom of the engine under the oil injection pump. I carefully installed a brand new pump and o-ring and the inlet and outlet hoses but the leak is still there, about 1/4 cup of oil per hour. I felt around the bottom of oil pump and hoses but nothing was wet so it appears that the leak could be coming from somewhere else. There is no smell of gasoline and the leaking oil is a blue-green color, the same as the oil I use in the injection oil reservoir. It doesn't appear to be the blacker gear oil from the drive unit. Help! I don't know how to fix it. Has anyone else had this problem?
Does anyone know a good Sport Jet mechanic in the Fort Myers area?
