Mercury stator question
tonydl86
1994 Mercury 4 cyl 125 hp Ser # OG039265 Model 1125412PD. I have a bad stator the number on the stator it self is 398-9710A31 this part is no longer available from Mercury, so I've called around looking for a replacement but Iam completely confused because everyone that I have talked to comes up with a diferent part number. I have an original part # stamped on the part a sre # and a mod # I cant understand why its so dificult. Can anyone offer some advice? <br />thanks.
graddy
Re: Mercury stator question
Mercury does have a stator for your engine, part #832075A8. Have your dealer look at Parts Bulletin 1996-01
clanton
Rapair has them, 2 stators 9 amp and a 16 amp. Rapair pn 9 amp 174-8778K1, 16 amp 174-9710K1
graddy
Never had much luck with Rapair parts. It's hard to get them to pay warranty. Mercury parts all have a 1 year warranty, parts and labor.
clanton
I met Rapair 1989, no problems with warranty, they ship warranty parts no charge, and I keep all parts until job is completed. Then return old parts, they paid freight both ways. I also know two techs that work for self, will not use a Rapair part.
tonydl86
Hey guys thanks a bunch!!!<br />DTS: one of the part numbers I came across is 832075A8, but its out of my range at $450 plus.<br /><br />Clanton, really glad to hear from you, you helped me trouble shoot my ignition problem all the way up to the stator. I took a while geting the tools made to get it out but its out now. mean time I lost track of you. the part you recomend is also one of the numbers I came up with, but since I was given diferent numbers, at the end I wasnt sure what to order.<br />Just to verify the part number for my Merc. is 174-9710K1 and this is a 16 amp stator is this correct? and do you have a number or a net adress to order it from ?. I apriciate your help hope to hear from you soon. thanks
skeets
Hi tony<br />rickracer online has a stator 3989710A11
tonydl86
I cheked rickracer.com but they seam to deal in auto parts. Is this the web address you are refering to.?
tonydl86
Clanton, how are you. If you are still monotoring this I'd just like to know if my engine takes the 9 or the 16 amp stator and does the regulator have to be changed also when using these substitute parts. who is a good distributer to get these from. thanks
