mercury trigger
shane1972
Hi, I'm new to the forums and I have a question. Im testing my trigger my ohm readings are 1650 my manual says readings should be between 1100 to 1400? Does this mean my trigger is bad? serial numbers on motor are 0G228310. I'm not getting any spark on all cylinders
Faztbullet
There are 3 coils on a trigger so all 3 going bad is highly unlikely....most likely the stator or switch issue.
shane1972
Thanks Faztbullet i just changed stator so that should rule it out. I was leaning towards the switch boxes myself. I got the boat from my uncle which had been sitting up for years.
