Mercury trim/tilt pump seized
wargle2
I have a 94, 90 hp Mercury and the three ram trim/tilt system with the square, Eaton motor. The pump has locked up. Everything was good last fall when I put the boat under the shed for the winter. The motor was resting on the "transom saver". This Spring, while getting ready for a trip, the trim/tilt wouldn't move. I checked voltage, relays, etc. I removed the motor/pump there was no water in the system, but the fluid was low, maybe 1/2 to 2/3 full. I separated the motor and pump and tried to turn the pump with an allen wrench and had to use pliers and a lot of force just to move it a little. I have heard these pumps are not serviceable. Does anyone have any information on this kind of pump or where I could find a replacement, pump only? Thanks.
fstrnuthink
Re: Mercury trim/tilt pump seized
I believe you have to get them from Merc.Mine had to replaced on my 200 Black Max.It took the dealer a week to get from Merc. I pick it up tomorrow.800.00.:mad:
Sink_Tip
I just bought a complete used tilt/trim 3 ram, 3 wire, square motor with side fill for my 70hp on epay for $230 including shipping. It's nice and clean and works great. The other style with the 3 ram, 2 wire, round motor with the aft fill will fit between the brackets but you will need a relay kit to make it work properly.
You can find new replacement motors on epay for about $80 and new motor/pump cartridge units for around $200.
In my case, the PO had removed the zinc anode and the unit was used in salt so the housing was in very rough shape. I wanted to start with a nice clean fresh water unit. If you buy used get a fresh water unit and make sure to get the anode!
Hope this helps.
Chris1956
Honorary Supreme Mariner
Wargle, Arco makes aftermarket PTT motors. They are likely cheaper than OEM.
wargle2
Thanks for the help, guys. I will investigate your suggestions.:)
