Mercury XR4 150
Seamay
Hello, new to the board and relatively new to boating. I was looking to get some input on a Merc XR4 150HP which is on a 95 Nitro 19` Bass boat. I have ran searches but I could not find this particular motor or any reviews. This boat is some distance from me so before I make the trip I was hoping to get a "typically problematic" or "not problematic" opinions. Thanks
Chris1956
Re: Mercury XR4 150
Sea, That motor was made a long time, and was very successful. If it is a '94 or so, it might be a 2.0 liter V6. Newer motors are 2.4 Liter, but with the same design and similar starting/ignition/charging components.
I just bought a '93 135HP V6. It shows great low end power, and good mid and high end power as well. Mine is a premix (oil injection was disconnected), which is convenient and desirable for me. The design and components are standard and replacements are available aftermarket, if necessary. The lower unit is a standard V6 LU, and shares props with the Alpha I sterndrive.
Now you need to look it over to see its external condition, as well as check the compression to see it's internal condition.
j_martin
Re: Mercury XR4 150
I have a 88 XR4 on an 88 18' Tracker boat. The Tracker was the Precursor to the Nitro series. That's about a 60 MPH combo, set for fishing. Would probably do over 70 if you left the batteries and fishing gear ashore and set it up high enough to get squirrely.
It is a 2.4L, vertical reed powerhead on a 4 in lower. It actually produced over 160 HP right out of the crate. It is about the max that a certified 150 could be. Very popular with the bass crowd, as it pushed the outside of the 150 horse limit of it's time.
I suspect that engine is a bit older than '95 , or modified. Could be a crap shoot. The 2.0, 2.4, and 2.5 L power heads will all bolt up to either size lower units.
pros:
It is a torque producing beast that has a neck snappinghole shot with a high five prop on it. The little lower makes it a bit faster than the newer XR engines with the larger lower unit.
It runs well in the 5800 rpm range, and if in good tune will idle for awhile also.
Props can be hard to find that can handle that HP in the smaller LU size.
Cons:
Be sure it gets enough fuel, or kiss pistons goodby. The stock thumb sized fuel filter is junk. Discard it and put in a Racor fuel filter/water seperator. Hoses, primer bulb, and the bayonet connector are all critical, where they wouldn't be on a lower HP V6. It's a big one, but hooks up like the little ones.
Keep the LU well maintained. Any thing wrong and it'll put the pinion out the side in a heartbeat. It's a little small for the engine size, but performs like a champ when it's in good shape.
Many good used parts are available. Shouldn't cost much to keep up.
It's not a new motor design. It will use fuel by the bucket, but so will any similar aged motor.
hope it helps
John
jebeebe
Re: Mercury XR4 150
I had an 89' xr4 150 on an 18' Lund pro-v. It was a screemer and I never had a bit of trouble for 10-12 years. It ate it's share of fuel, but it would hit 55-57mph and get there quick.
The regular 150 had a larger lower unit and took a different prop than the xr4. The xr4 had a slimmer smaller lower unit and cut the water better but wasn't as beefy. Like I say.........good motor and dependable................................Jerry
