Lonepiper
- Joined
- Jun 10, 2009
- 45
As you can see in the pic below, the center window on my MFG Gypsy 15 seems to be drooping almost 1/2 inch down. I would like to know three things:
1-How do I resolve this?
2-The pane in the center window had been replaced as some point in the past with plexiglass or some clear plastic material. It is now hazy and has a crack at teh bottom. How do I replace it. I haven't measured yet but upon consideration, it may be cut wrong and be the cause of #1. But I still want to replace it. Guess I can ask hardware store what type would be good. I do stained glass so cutting is not a problem
and 3- how do I eventually remove the entire window?
Thanks again for all the help, this forum is most excellent!
