Woodonglass
Honorary Supreme Mariner
- Joined
- Dec 29, 2009
- 25,933
Re: MFG rebuild getting started pics
Yep wet with either one. You don't need much abrasiveness, just enuf to knock the nubs off and scuff the surface to give the next coat some bite. I used the scotch brite and it worked great. Paint with the hardener will/should not load up the paper. If it does you're sanding to soon. Minimum of 4 hours cure before sanding and next coat.
