MFG rebuild getting started pics
sphelps
Re: MFG rebuild getting started pics
Yep I think they wet sanded it or something . I don,t think its in that bad shape for something to aggressive ..
sphelps
Hard to believe I have already gone thru over 2 gal of resin on these bases .
I will probably just put 2 layers csm on the outside and one on the inside .
Have a great week everyone !
Trooper82
That CSM really drinks the resin...looking good SP...
jbcurt00
Well if the underside is any indication, the topsides will look great when you're done & they're painted to match!
Decker83
Your glass work on the seat base's looks great. Your turning into a pro.:D
GT1000000
Man those seat bases look like they could do double duty as jack stands for a semi...awesome job S.P.:D
th
jbcurt00
Thats the 1 :facepalm:
Besides, if the Admiral won't give you 30min (+/- :redface:) you'd just be fidgety, fiddling w/ your smart phone and jones'in for an iboats fix ALL DAY.
30 min (+/- :redface:) is just enough to quell the nerves ;) And won't really cut into your anniversary time.
I found my 30min late in the afternoon during the 'getting' ready for dinner hour :rolleyes: while we were at the beach last month.........
sphelps
Yep but I sure hate to put em on the scale.
Shhhhh!!!! Don't tell the admiral I snuck on here..
Don,t worry your secret is safe here !
Ahhhhhhh.....i'm tellin'!!!!!!
Careful you could be in violation of the guy code !
Yep Iwould think that would be the best time to sneak in some iboats time..
I don,t think I,m in any danger of loosing my amateur status !
GT1000000
Jeez, 30 min...that's like barely enuff to get a fix...:facepalm:
sphelps
Started getting the windshield ready to install . There are still a few scratches but it looks ok ..
The seat bases came in handy in the cleaning process .
These mounting brackets could have been a little longer on the flat part .
The mounting holes on the windshield are a little high making the gasket bulge around the post .
Not sure how I can fix this other than maybe cutting the rubber around the post to let the gasket lay flat .
Any idea,s ?
I wonder if Jon had the same trouble . Probably not because his was a new windshield and he could drill the holes in the right spot ..
jbcurt00
Windshield looks great.
Gasket bulge, yeah sorry:
Trooper82
Wow...shiny!
The windshield came out looking great....
kinda hard to tell from the pics...is the bracket coming up perpindicular to the hull? What would it look like if you you cut 1/4" out of the side the bracket is on and leave the other side whole?
sphelps
You mean cut the gasket right ? I was thinking about that . I would hate to do it but I think it would help ..
Trooper82
Ya, that is the inside edge right? Maybe cut it in the center of bracket, then cut 45 deg angle .....so the first cut could be put back with 5200 or sealer?
I'll have to go draw it up to explain it a little better...on ipad and can't figure out how to from here :facepalm:
sphelps
I get what you are saying and that sounds like a good idea ..;)
Decker83
The windshield looks great.
You may want to check with the manufacture and see if the make a longer one.
sphelps
Thanks Decker ! This is the only size Taylormade makes of this type .:mad: I had to go ahead and make it work .
Welp it,s on there .For such a small project it took me most of the day.LOL !
Still need to polish up the trim and secure it . Hope I can find some of those itty bitty rivets . Or maybe some really small ss screws..
Insert motor boat sounds here !
As you can see from the jump seat view . I am going to have to notch the front corners of the front seat bases in to the hull to get the seats to line up properly . Gunna set the HT on this week to test the seat height before I finish the glass work on the bases ..
Hope everyone had a fun / productive week end !
