MFS25A lower foot seal
Tohatsuguy9
Good evening community,
I recently noticed my foot leaking blue oil (foot oil) fairly rapidly. I looked for a seal kit and I found a diagram that shows only one “oil seal” present. The other parts on the diagram that look like seals are labeled bearings. My question is, does the MFS25A (2003 I know year is not relevant) only have one seal to replace? Thanks in advance.-Juan
pvanv
3r0873211mlower unit gasket set$28.73
There are driveshaft seal, prop shaft seal, prop housing o-ring, a couple of shift bushing o-rings... etc.
km1125
Do you know what's actually leaking? Have you done a pressure test on it to check for leaks?
Tohatsuguy9
I do not. It looks like it is coming from the very front seal but I will have to investigate further. I am not sure why the leak started but it is leaking at a very fast rate, like something internal busted.
