Re: michigan prop ID
Well, if you swap lower units, you'll likely have a different gear ratio, so it may not be the same prop.
As for running 350HP with the pre-alpha lower, you probably better stay close to shore.
At 17HP required per mph gain, you'll be looking (in theory) at 5.3mph gain for adding 90HP.
If you figure in the additional lift of the boat, maybe 2 more mph.
Although I don't believe that lower unit will handle that HP, the 21P won't be far off, possibly a 22P depending on what RPM you're looking at.
