Re: micro thin layer of resin to fill in crazing?
I think you're in for some gel work. There should be some info on here how to do the gel work, if not someone will chime in and walk you through it. From what I am gathering I would brace for the following steps.
- sand off the gel till mostly down to bare glass.
- layup 1-2 layers of CMS over the hull with poly resin (this will stabilize the surface and cover the cracks/prevent from printing through again)
- fare the surface with some thickened gel
- sand smooth and spray the new gel (or prime for paint). Choice is yours, there are positives and neg's to each approach. If it's more of a work boat then I might lean more towards gel simply for durability.
- Wetsand, buff and have a few cocktails
Now, this info is for a project sight unseen. It might be what you need, might not. If you can post some pics we'll know for sure..
