Re: microplus 571
ok.....where do i start......first of all....sorry i was away for a few days,
wrecks......i thought that boat looked a little too "clean"
from what i can see in the pics......i believe you boat has been totally restored.
(thats a good......great thing)....the two "repair" pics are of a stringer sistering attempt in the forward bow area......they used enough glass on there not to worry about it much.....i however, would do a core sample in that area, and some farther back.
that bilge pump set up is about the worst ive seen before......it was put there because at one time the hull leaked, ant the water ran between the hull and the deck where the foam used to be.
thats why the bilge pump is cut into the deck.
id check that and make sure the leak was gone
in post 13 middle pic......see that thin space there......that aint stock....its sooo tough to tell what and and where we are looking at but over all bud......it looks really really good.
any problem areas that you have questions about?
cheers
oops
