Re: Mid 70's Mercury 1750 Outboard
Ahoy, Winger! Welcome to the board. This is the best place to get advice and opinion.<br /><br />Six years, huh?<br /><br />First, buy yourself a manual. Clymer publishes a good one.<br /><br />Remove the spark plugs and squirt a bit of WD-40 in each cylinder. By hand, turn the flywheel through several turns or until it turns smoothly and with little effort.<br /><br />Next, dismantle and clean the carbs, with special attention to jets and other small passages.<br /><br />Put an overhaul kit in your fuel pump.<br /><br />Replace the water pump impeller and the grease in the lower end.<br /><br />If all of the above goes smoothly, check for spark by turning the engine over with the starter. If each plug fires blue, reinstall them.<br /><br />Fresh 86 octane fuel, mixed 50:1 with TC-W3 rated 2 stroke oil. Clean tank, new hose and primer bulb. "Earmuffs" on water intakes. Water on. Start her up.<br /><br />I trust our colleagues to point out anything I have overlooked.<br /><br />Let us know how it goes.<br /><br />Red sky at night... <br />JB
