Eddie Mullins
Thread starter- Joined
- Apr 14, 2009
- 38
I have a mid 80's 35 HP which starts and runs fine - unless I am at WOT. It will run fine for a little while and then stall. When it does this I have noticed the bulb want be firm/filled and I can often pump it manually and get it to line back out, or if I just throttle down a little it will line back out.
I have check the pick up tube in the tank and it seems fine. I can't find a fuel filter to replace so I am assuming I don't have one. I thought aboutl replacing the fuel line, bulb and connector just incase there is an air leak somewhere but I don't see any cracks.
This is my first boat so I'm starting from scratch here - and any suggestions would be appreciated.
