Bspaulding
Thread starter- Joined
- Dec 13, 2020
- 6
I recently bought a mid 90s Johnson 115 2-stroke to put on my 72 Grady White. I have replaced the fuel pump, starter, and head gasket, changed the spark plugs, and water pump. It runs fine in the driveway on muffs (throttles up/down and goes into gear and runs), but as soon as I get it into the water, it is difficult to start and if I have the choke up, it goes WFO (wide effin open) but as soon as I put the choke off, it bogs down and dies. I have taken it out and usually have to use the primer solenoid to make it out of the ramp and even at full throttle sounds like it’s bogging down and has little power. I took off the carbs and cleaned the bowls out but didn’t clean out the fuel lines. Any suggestions for why this is happening? I am attaching a video of it idling on muffs. I have seen this question posted on other threads but I have not come across a solution for my engine so far. I have also not done a compression test but engine does not sounds like it’s missing. I have run seafoam through it and it did not change anything. The smoke in the video is off of a oil rich mixture about 45:1 of oil and ethanol free 93 octane.
Also, I have been a gas/diesel mechanic for the past 15 years or so working on heavy equipment. I am mechanically inclined but this is the first time I’ve owned a boat and have worked on a boat motor.
View attachment IMG_4155.MOV
